XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 03-30-2008, 10:33 PM   #1
RAID
RAID's Avatar
Q9450 OC / Temps / Settings
http://valid.x86-secret.com/show_oc.php?id=337218
Just wondering what settings you guys were using to OC your new chips. the Q9450 oc up to 3.8 with no other adjustments besides setting the fsb and everything else on auto.
for 3.95, i had vcore - 1.4, vtt - 1.6, pll -1.6, nb -1.7, sb 1.6
really happy with the chip so far. i'm sure it will hit over 4GHz easily, just don't want to push the voltages much more. advice is greatly appreciated.
temps are great, btw
RAID is offline   Reply With Quote
Old 03-30-2008, 10:39 PM   #2
RunawayPrisoner
Nice clocks! And you almost beat my 500 x 8 validate, too.
__________________
Motherboard: ASUS P5Q
CPU: Intel Core 2 Quad Q9450 @ 3.20GHz (1.07v vCore! )
RAM: 2GB Kingston HyperX 800MHz
GPU: MSI Radeon HD 4870 @ 780/1000 (default)
RunawayPrisoner is offline   Reply With Quote
Old 03-30-2008, 10:50 PM   #3
RAID
RAID's Avatar
thanks, what settings did you use to get 500? the chip hits 3.8 in a blink and i haven't even crossed 1.4vcore. just trying to get the board stable above 500 as i feel the quad has a lot more to offer
*shakes fist at 8x*
Old 03-30-2008, 10:56 PM   #4
RunawayPrisoner
Well, it required 1.45v vCore, 1.5v VTT, 1.6v PLL, and 1.7v NB. I couldn't do much aside from doing a quick SuperPI 1M and a validate link.
3.80GHz requires 1.344v idle and 1.312v load for me. It's rock solid from then on at 3.80GHz, though, so I guess this is my golden state.
__________________
Old 03-30-2008, 11:02 PM   #5
RAID
RAID's Avatar
thanks, i'm running smoothly 3.9 at 1.36vcore right now. i have to get my NB under water tomorrow and then i'll feel more comfortable with giving it more juice.
i'll give your settings a quick look tonight though, thank you RP.
Old 03-30-2008, 11:15 PM   #6
RunawayPrisoner
You're welcome. And good luck with the chip.
__________________
Old 03-31-2008, 07:27 AM   #7
sbinh
Mind to list all your settings? board? RAM? .....
Thanks.
Edit: .. Duh .. nevermind about RAM & board. .. Did not see the CPUz report.
__________________
Last edited by sbinh; 03-31-2008 at 09:10 AM. Reason: did not see the CPUz report.
sbinh is offline   Reply With Quote
Old 03-31-2008, 08:06 AM   #8
Aldy402
Aldy402's Avatar
I'm surprised you didn't have to raise the NB voltage for 3.8ghz
good job. In your experience, how limiting is the 8x multiplier?
__________________
q6600 g0@3.6ghz [DFI LT X48-T2R] 1.4V
8gb gskill f2-8000cl5d-4gbpq
1tb wd black
evga gtx 260 [fuZion gfx 2 /w unisink] + x-fi xtrememusic
corsair hx-620w + lian li pc201b + dell 2408fpw
3/8" tygon r3400/d-tek fuzion/mcw30/petra ddc2+/thermochill pa120.3 with scythe s-flex "e"
*built for silence
Aldy402 is offline   Reply With Quote
Old 03-31-2008, 08:14 AM   #9
emoners
emoners's Avatar
i had vcore - 1.4, vtt - 1.6, pll -1.6, nb -1.7, sb 1.6 --> WOW voltages!
__________________
ZOTAC® GeForce™ 9300-ITX WiFi Rev.01 (+ Noctua® NC-U6) | Intel® Core2Quad™ Q9400 L910B375| OCZ® NVidia SLI-Ready DDR2-6400 2x2Gb | PowerColor® ATI™ Radeon HD4770 | Western Digital® Caviar™ Black 1Tb | Silverstone® Sugo™ SG05 | Windows® 7 Ultimate 32-bit
RETIRED:
• DFI® LanParty™ UT P35-T2R Rev A02 (05/21 Bios) | DFI® LanParty™ JR P45-T2RS Rev A03 (10/07 Bios) | Intel® D945GCLF2 Little Falls-2 | Intel® Core2Duo™ E6850 L723A348 | Intel® Core2Duo™ E8400 Q746A446 | Intel® Core2Quad™ Q6600 L723B837 | Intel® Core2Duo™ E7400 3849A508 | Intel® ATOM™ 330 | XFX® NVidia™ GeForce 8800GTX | XFX® NVidia™ 8800GT XT Alpha Dog Edition | Creative® Sound Blaster™ X-Fi Fatal1ty XtremeGamer Pro
emoners is offline   Reply With Quote
Old 03-31-2008, 08:18 AM   #10
Aivas47a
I am Xtreme
Aivas47a's Avatar
Those volts esp. 1.6 vtt seem pretty high for 45nm.
__________________
W3520 @ 4.4 ghz | DFI UT X58 | Swiftech GTZ | 6G Kingston 2000 | 4870 | PCP&C Silencer 750w | Win 7 RC
Aivas47a is offline   Reply With Quote
Old 03-31-2008, 09:03 AM   #11
sofarfrome
sofarfrome's Avatar
That seems to be the problem with these quad 45nm chips. The need for relatively low vcore (mine needed 1.298 to be 3.6GHz P95 small ffts) but a ton of NB and VTT to get it blend stable.
__________________
DFI LP LT X38; Intel E8600; Crucial 10th Anniversary DDR2-667 (2x1GB); eVGA 8800GT 512MB; WD 250MB Sata-ll (and others); Silverstone Striker 750W; D-Tek Fuzion-TC PA120.3-Swiftech MP655; Lian Li G70B; XP32 SP3
DFI LP P45 Jr.; Intel E8400; Crucial Ballistix DDR2-1066 (2x1GB); Custom WC setup; PNY 9800GTX; Corsair 620HX; Plextor DVD; Lian Li; Logitech G11/MX510; Lian Li; Vista Ultimate 32 bit
The clueless don't even know they are.
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe. -- Einstein
HEAT
sofarfrome is offline   Reply With Quote
Old 03-31-2008, 12:00 PM   #12
RunawayPrisoner
Mmm... I was just wondering. RAID, could you try to manually select your voltages and see what would make 3.80GHz stable? 1.6v VTT seems very high to me, and I hope your board is not defaulting (or automating) to that.
__________________
Old 03-31-2008, 12:15 PM   #13
graysky
So is that a function of the P35 chipset? Anyone using an X38/48-based board w/ these 45nm quads? Do they require the high NB and VTT like sofarfrome has reported?
__________________
graysky is offline   Reply With Quote
Old 03-31-2008, 12:21 PM   #14
RunawayPrisoner
Hmm... I don't know if my input is relevant to your question, but I'm using G35 here, and the only high voltage I need for the chip to be stable is vNB.
__________________
Old 03-31-2008, 12:39 PM   #15
seraphi
I need 1.6vtt to get to 3.6ghz
__________________
Intel Xeon x3350 Quad Core /w OCZ Freeze
Thermalright IFX-14 /w 2x Scythe S-Flex Fan SFF21F 63.7cfm@28.0dBA
DFI LanParty LT X48-T2R
4x2GB Mushkin Redline PC2 8000
2x Seagate 7200.11 500GB 32MB RAID-0
EVGA GeForce 8800GTS (G92) 512MB
CoolerMaster Cosmos 1000 case w/ 5x Scythe S-Flex fan SFF21F 63.7cfm@28.0dBA
Thermaltake Toughpower 850W PSU /w BELKIN 1500VA UPS
Samsung 2253BW 22"
Vista 64 Ultimate
seraphi is offline   Reply With Quote
Old 03-31-2008, 01:11 PM   #16
graysky
@deraphi - cool, so you're using the LT x48-t2r... even though there isn't official x3350 support in the BIOS, it's obviously working for you. What kinda numbers are you running w/ it besides 8x450? Also, is it p95 stable @ 3.6 GHz? What kinda voltages is needed and what kinda motherboard and CPU temps are you getting?
Finally, how do you like the MB? I was thinking about it but $270 is kinda expensive... I was gonna get the LT P35 version for $170.
__________________
Old 03-31-2008, 01:40 PM   #17
cbutters
I needed 1.6 CPU VTT and 1.6NB for 3.6ghz stable prime blend with my x3350(q9450) using a X48-T2R.
I didn't want to run so much voltage through it, so i bumped it to 3.5ghz which only required 1.43CPU VTT and 1.43 NB
Ive been reading however that 450FSB to 460FSB has issues, and 461 FSB and higher might be able to do better than 450, I might test that a little later.
Also, I haven't played seriously with GTL settings either yet. I need some more research to be done before I tackle that one.
__________________
VISIT MY WEBSITE: www.exoid.com
Tweak your Life!
cbutters is offline   Reply With Quote
Old 03-31-2008, 02:01 PM   #18
RunawayPrisoner
Mmm... did you guys ever try... backing down the VTT and the vPLL? I think 1.6 VTT is just too overkill. Without any GTL modification (I don't even have the option to), it just requires me 1.32v VTT for 3.80GHz stable. Are you sure... that that's necessary?
__________________
Old 03-31-2008, 02:21 PM   #19
Aivas47a
I am Xtreme
Aivas47a's Avatar
Don't some boards (DFI P35, IIRC) have a feature that detects if you're using a 45nm cpu and, if so, lowers the stock VTT to 1.1 and caps the max at 1.5?
__________________
Old 03-31-2008, 02:26 PM   #20
RunawayPrisoner
Yes. I believe that's what my board is doing. 1.5v is the max I can go to with my X3350 and my E8400. But 1.6v is still too high..
__________________
Old 03-31-2008, 02:48 PM   #21
Delirious.
Delirious.'s Avatar
I can get mine to 3.9, but right now I am getting a rounding error on one of the cores at 1 hour and 20 minutes of small fft @ 3.8 ghz.
My voltages are:
CPU 1.43 Actual 1.37
FSB 1.35
Memory 2.0
SPP 1.45
MCP 1.55
Any recommendations. I may need to bump up the VCORE.
__________________
GTX 280 in TRI-SLI - 180.48 P33198
EVGA 790I FTW Digital With Bitspower watercooling
QX9770 @ 4 - 24/7, 4.6 for benching
Supertalent Project X 1800mhz. 2X2 gb DDR3 8-8-8-24 2T - 1.9 volts
1200 Watt Thermaltake modular
Dtek Fuzion with Thermochill PA 120.3
Lian Li V2000 Case
Delirious. is offline   Reply With Quote
Old 03-31-2008, 04:46 PM   #22
viol37
Hi RAID,
I also own a Q9450, which is currently running quite stable at 3.4Ghz running at an idle temp of approx 40.
I'm also running all default voltages.
Based on my below specs, do you think I can increase the clockspeed beyond 3.4Ghz?
I'm thinking that maybe to why you are able to OC to 3.8Ghz is due to you running the nforce 790i with DDR3 OCZ Ram modules.
Your thoughts mate?
My Specs:
Asus Striker II Fomula (1333 FSB)
Intel® Core™2 Quad Q9450 2.66Ghz @ 3.4Ghz
ThermalTake Toughpower 750 watt (modular)
Zalman CNPS 9700NT (100% Pure Copper)
x2 Corsair Twin2X Dominator 2048MB PC8500 (1066Mhz) = 4096MB
x3 Western Digital Raptor 74GB 10000 RPM 16MB Buffer = 207GB (RAID 0)
x2 Inno3D GeForce 8800GTS 512MB DDR3 OC Edition (700/2000Mhz) = SLI
Custom 1.44MB with Integrated Card Reader (CF, SD, MMC, SM, MemoryStick, Microdrives)
SoundBlaster X-Fi XtremeGamer
Samsung 226BW 1680x1050 2ms (DVI)
Microsoft Vista Ultimate (64bit)
viol37 is offline   Reply With Quote
Old 03-31-2008, 04:56 PM   #23
sbinh
I am currently running it on P5K-Dlx at 3.6GHz (FSB=450).
Still trying to get it higher but not succeed yet. OCCT failed at FSB=460 within first 5 minutes.
Idle temp~43*C and loaded temp ~56*C
__________________
Old 03-31-2008, 05:24 PM   #24
sofarfrome
sofarfrome's Avatar
My voltages are:
FSB 1.35
Memory 2.0
SPP 1.45
MCP 1.55
vcore is not an issue on these chips...you need higher NB voltage and higher NB VTT.
__________________
HEAT
Old 03-31-2008, 05:27 PM   #25
sofarfrome
sofarfrome's Avatar
Dude, you have a very good chip. So far I have only seen one other chip that will run 3.8-3.9 stable without a ton of voltages on the NB and VTT and that one is a Q9450.
Not everyone is going to realize the same success you did.
__________________
HEAT
Reply
Tags
q9450
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
